Hit radius icon > R > ENTER > Type radius eg. 50 > ENTER > left click on both sides of both polyline where you want radius to appear
SIMPLE AS THAT...No time wasted P editing!!!
FILLETRAD
50
FILLET
pick two objects to fillet
Or automate by modifying your FILLET macro on the screen to always prompt you for a radius:
^C^C_FILLETRAD;\_FILLET
Hi Dean,
I tried your macro and it worked except it wants to repeate the last radius used. Is there a way to have it prompt for a radius as soon as I enter "F" rather than having to go though hitting the down arrow and selecting radius?
Only if you want to buy full AutoCAD and rewrite the macro as a Lisp routine.
If you just want the macro to constantly repeat until you cancel it deliberately, modify it with a star at the beginning, like this:
*^C^C_FILLETRAD;\_FILLET
Then either hit <enter> to accept the default radius presented and keep clicking lines to fillet.
Try to shortcut FILLETRAD command (FR for example), then you can invoke FR when you need it but continue with F for as long as that one setting is valid. Of course I'm not sure that's any faster than just typing through the FILLET command.
Thanks for the info Dean. As slow as my typing is any keystroke I can avoid saves time
