First: TIFEXP is not what i am looking for.
I do not print regular to paper but into a file. I use a special "printer" driver to print to a tif-file. The tif-file is a black-and-white classic "blueprint". LT 2014 produces a filename that looks like this:
M__pk_dwg_39000_39200_39257-a1 Model (1).tif
I simply need the filename itself:
39257-a1.tif
How can i change this?
Solved by pendean. Go to Solution.
Solved by MICUnna59423. Go to Solution.
What is FULLPLOTPATH set to?
Make sure it is 0
Howard Walker
FULLPLOTPATH was 1, is now set to 0.
Thats half the way.
Can i leave off the "MODEL(1)" as easy as that?
Thanks very much so far.
Reading on other threads in this forum. That should work, but I never plot to tiffs.
Howard Walker
