AutoCAD LT Forum
Filename when printing to a file
5 REPLIES 5
MICUnna59423
484 Views, 5 Replies
First: TIFEXP is not what i am looking for.
I do not print regular to paper but into a file. I use a special "printer" driver to print to a tif-file. The tif-file is a black-and-white classic "blueprint". LT 2014 produces a filename that looks like this:
M__pk_dwg_39000_39200_39257-a1 Model (1).tif
I simply need the filename itself:
39257-a1.tif
How can i change this?
5 REPLIES 5
MICUnna59423
in reply to: MICUnna59423
To be more precise: I want to leave off the full path before and the "Model(1)" behind the filename. The drawing name is "39257-a1.dwg" in the above example, located in that path.
hwalker
What is FULLPLOTPATH set to?
Make sure it is 0
Howard Walker
Left Handed and Proud
MICUnna59423
in reply to: hwalker
FULLPLOTPATH was 1, is now set to 0.
Thats half the way.
Can i leave off the "MODEL(1)" as easy as that?
Thanks very much so far.
hwalker
Reading on other threads in this forum. That should work, but I never plot to tiffs.
Howard Walker
pendean
You can't get rid of the tab name coming along AFAIK.
”Boost
