Show only
Search instead for
We are using Autocad Light 2002 for the first time on our network. Our students are not able to browse to network-drives anymore, only local and removable drives are availiable in the file open/save dialogs. Other programs work without any problems. We are using Autocad light 2002, WindowsXP on a Netware 5.1 network. Please help!
There is no such LT limitation: you might want to check your log-in
requirements for your students, LT and AutoCAD 2002 require ADMIN or
POWERUSER access to operate successfully.
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
When I am using Autocad I also have the same problem (I have network & local admin rights!). Still don't see network drives in Autocad. As I mentioned: Word, Excel, everthing else has no problems, I can use all network drives.
Try asking in Networking discussion area, you may have a specific correction
that needs to be performed with your network type.
news://discussion.autodesk.com/autodesk.autocad.network
or
http://discussion.autodesk.com/WebX?14@217.DFeIaZBtuCI.1@.ee77eff
Dean Saadallah
