>>>The bottom line? All I really want to do is get rid of the old version,
but it's locked status appears to prevent this.<<<
It's not AutoCAD that is locking it, it's your OS or Server is what I am
trying to say here: if you cannot right click on the file in the server,
select Properties, and remove the READ ONLY tag attached to it, you need to
stop using your server as it is slowly going to completely trash your entire
office's access to all files you have on it.
This is not the place for the kind of help you need: you need to provide
full specifications on your server, details and summary and connections to
PCs, Windows versions throughout, type of network, drives and everything
else someone not in your office needs, then you post either at Microsoft's
website, Novell's (if that is what your network is), or Compaq's (or however
your server creator is), or one of these locations:
news://discussion.autodesk.com/autodesk.autocad.network
http://discussion.autodesk.com/WebX?14@81.mHbbagFYoof.0@.ee77eff
news://discussion.autodesk.com/pn.hardware
http://discussion.autodesk.com/WebX?14@93.9H2UagZYoAc.0@.f10501c
Dean Saadallah
http://www.pendean.com
LT Express Utilities
http://www.pendean.com/ltexpress
Expanded Links Pages
http://www.pendean.com/lt/links.htm
