Send them the file you use, R2000 format: tell them 'regular' Microstation
can open these with no problems. Latest version of Microstation as no
problem reading latest files from AutoCAD, so it looks like they may have to
upgrade.
Do NOT set SAVE to R14 format, leave it R2000 format and save.
AUDIT and see if there are errors in your file that can be fixed. Then use
SAVEAS and save a copy of the file in R14 format, then try and open it.
Most likely, the 'round-trip' information stored in the file when you save
down may be interfering with their translator, but that is something they
need to upgrade/update, you cannot do anything about it.
You could try using SAVEAS, select R12DXF format, and send them that file:
that's pretty much universal.
LT and AutoCAD, 2000 through 2002, create the same identical DWG file.
Nothing is different.
Dean Saadallah
http://www.pendean.com
LT Express Utilities
http://www.pendean.com/ltexpress
Expanded Links Pages
http://www.pendean.com/lt/links.htm
