Well, there are quite a few things you could try, to at least eliminate the
PC and Windows ME as the problem first:
-Uninstall your anti-virus software;
-Remove all MS Office apps from your START>PROGRAMS>STARTUP folder;
-Remove your network card, and Uninstall the drivers;
-Update your video card drivers;
-If you have a ZIP drive, updated drivers from IOMEGA's website is
recommended at this point in 2002;
-In Windows>Display, turn down screen resolution to 800x600, 256 colors, and
turn off completely video card hardware acceleration;
-Run AUDIT (answer yes to fix errors), or RECOVER on both the file you are
having problems (and all Xrefs, individually, attached to it) with and the
block you are dragging in with ADCENTER;
-Make sure both the file and the block you are dragging in are the same
version of AutoCAD as what you are using;
-Restart your PC after each of the above happens and make sure settings
stick;
-Do a repair install of 2002;
-Restart your PC again.
-Now try the drag and drop, of course with both files on your local HD.
-If all works, start putting back items above, one at a time, restarting
your PC and testing 2002 after everyone, until the culprit is identified.
-Your problem may well be WindowsME if it was an upgrade install (some here
would even say WindowsME is the problem).
If you are still having problems, post both the master file and the block or
blocks to Customer Files discussion area for others here to try in 2002: at
least someone can determine if it is the files, or your system that is the
problem.
As for my AUTOSAVE comment, relying on it is never a good idea, as it really
does not work as good as, or as reliably as a manual QSAVE: learn to QSAVE
more often, even repeatedly. Make it a quick key command or something more
convenient, and make sure a BAK file is always created. Worried that the BAK
file might be too old? Then double QSAVE.
Dean Saadallah
www.pendean.com
"Jason Dexter" wrote in message
news:DA84AE1FE1F6B2127F2F2FA32C797DF0@in.WebX.maYIadrTaRb...
> Well, the same error occurred again... this time Auto Save was turned off
as
> you reccomended, Dean... any other thoughts... this error would be at
least
> tolerable if it didn't freeze up AutoCAD and not allow me to recover the
> work since my last quick save...
> Jason
> "Dean Saadallah" wrote in message
> news:DF52206643BCDD0D1A3730CA66B9AC18@in.WebX.maYIadrTaRb...
> > Turn AUTOSAVE off, set ISAVEPERCENT to 0 (zero), QSAVE, then drag the
file
> > in from ADCENTER, and see if the problem is repeated.
> > Dean Saadallah
> > www.pendean.com
> > news:F85BCFA1BA890B4AD7BAE4A2F6E7071F@in.WebX.maYIadrTaRb...
> > > I have had the following Fatal Error: Unhandled Access Violation
Reading
> > > 0x4dcb976 Exception At 36020db4h several times today... It occurs
> whenever
> > > the following cicumnstances happen simultaneously:
> > > I drag a block from the Design Center to the drawing...
> > > An Automatic Save begins...
> > > I am running Windows ME on a P3- 866 with 256M RAM... Any assitance
> would
> > be
> > > appreciated
> > > Also why doesn't Autodesk have any patches, or if they do where are
> > they...
> > > they only have a patch for upgraders, that I can find.
> > > If any responses can be copied to jdexter@paxtontech.com, that would
be
> > > great, thanks.
