Angelo,
The error about the DLL is the result of Win9X not resolving the common
shared files path. For more information refer to the online Knowledge Base.
Similar error with solutions:
http://support02.autodesk.com/knowledgebase/html/274012.htm
Knowledge Base
http://support02.autodesk.com/ViewAnswerworks.asp
Sincerely,
Shaan Hurley
Autodesk Beta Programs
http://betaprograms.autodesk.com
"Angelo Vos"
wrote in message
news:170583F5D6FCD5252172604C6D5DF341@in.WebX.SaUCah8kaAW...
> I have just finished installing AutoCAD LT 2000i upgrade onto my PC and
> on every attempt at opening the program I get the Fatal Error:
> Unhandled Access Violation Writing 0xffffffd9 Exeption at 9h.
> - pentium II 128 mb int.
> - Windows 98
> - IE = 5.01
> - there is no TSR running.
> - no virus scans running.
> After installing service pack 2 (u091_u181p_lt) the program gives the
> following startup failor: "can not find required DLL-file, SHAREDB15.DLL.
So
> this solotion wasn't very usefull.
> - maybe it's better also re-install Lt 97?
> Plaese can someone give a usefull solotion?
> Greetings fram Angelo Vos Netherlands
> Angelo
> Angelo
