AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Fatal Error message when plotting to PDF
8 REPLIES 8
Message 1 of 9
LIITcom
5535 Views, 8 Replies
A user is having issues with plotting from AutoCAD LT, when trying attempting a normal plot to PDF the program crashes and he is forced to close it, also when changing the way he plots to plot to DWG PDF it starts to work correctly but brings up a fatal error message as below and attached:
FATAL ERROR: Unhandled Access Violation Writing 0x0014 Exception at 778e224dh
Any help would be greatly appreciated.
Thanks.
8 REPLIES 8
Message 2 of 9
pendean
in reply to: LIITcom
What version of LT?
Did the problem suddenly start? Or has something changd with the user (new LT seat, new computer, removed something...)?
And most importantly: is the problem in one file, ALL files, NEW files?
Message 3 of 9
LIITcom
in reply to: pendean
What version of LT?
I believe it is version 2007
He has said it suddenly started
Is within all files
Message 4 of 9
pendean
Windows Restore should reveal what changed between when it last worked and now.
If no one else offers another sugggestion, explore the Autodesk recommended uninstall and reinstall procedures:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=10243968&linkID=9240617
Try a simpler repair-reinstall first. Have your user backup first for easier recovery of any customizations.
Message 5 of 9
26111438
I am getting similar errors. I cannot plot to pdf, any drawing. I reinstalled windows and autocad and this repaired the problem temporarily and now it has inexplicably returned just today. FATAL ERROR: Unhandled c000000dh Exception at 237eb667h It goes like this: 1. Open any drawing. 2. Select any layout. 3. File > Plot > Select PDF as printer/plotter 4. Click OK 5. Plot job progress bar appears 6. Fatal Error Message 7. Total crash, AutoCAD closes Please help. I cannot do my job without it.
Message 6 of 9
pendean
in reply to: 26111438
>>>... this repaired the problem temporarily and now it has inexplicably returned...<<<
Software has no parts that break: something got added or deleted to your system that changed it. Windows Restore is a good start, turning off automatic Windows Updates and any other automated software chages may work.
Your issue is not LT related sadly, it's just the 'victim' of what is changing. Find out what that is.
Message 7 of 9
Charles_Shade
.NET update perhaps?
When you look at the Restore calendar of events.
You stated in the other thread that you had moved from LT 2008 to LT 2013.
Was there a hardware change as well?
Message 8 of 9
26111438
in reply to: Charles_Shade
Whatever the reason, it seems my file name was too long.  Over 17 characters seems to cause problems.  I shortened the file name(s) and can get the results I need now.
Message 9 of 9
pawanjain7434
hi,
i am using Auto cad 10, when i give plot command to make PDF file a problem occured that is
FATAL ERROR: unhandled c0000417h exception at 78556d36h
”Boost
