Hello
"Autocad LT 2013 SP1.1_32bit.exe is not a valid Win32 application" seems to mean that the EXE file is corrupted !?
Maybe you could redownload it and retry ?
Bye, Pat
Patrice BRAUD
New problem?
Old problem?
Something change on the OS?
Run a Registry Cleaner perhaps?
Any MS .NET updates installed?
Tried a System Restore to when AutoCAD worked if this is a new issue?
Installation and Licensing Forum:
http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
This is new problem we just encounter this error message this morning. I tried same procedure what I did in AutoCad LT 2012 fatal error. I tried to install the service pack 1.1 for AutoCAD LT 2013 but I received an error message "Autocad LT 2013 SP1.1_32bit.exe is not a valid Win32 application". Is there a System Restore for Autodesk?
JM.
