AutoCAD LT Forum
Fatal error in AutoCAD LT 2006
9 REPLIES 9
Message 1 of 10
stubbes
2181 Views, 9 Replies
Windows 7 - 64 bits receiving multiple fatal errors during the day:
FATAL ERROR: Unhandled Access Violation Reading 0x0000 Exception at 5fa187abh
Anyone have a solution for this?
9 REPLIES 9
Message 2 of 10
Charles_Shade
in reply to: stubbes
Welcome to the Autodesk Forums!
New problem?
Any Windows updates? Especailly .NET updates?
Waht changed on the computer recently?
Message 3 of 10
stubbes
in reply to: Charles_Shade
Has been going on for a couple of weeks now, no Windows updates in that period.
Message 4 of 10
pendean
... and most importantly: what triggers the crash?
BTW, LT2006 is not supported in Win7, you are so out of luck for official support. However, Microsoft offers so much free advice on installing old software in Win7 it's worth checking there and if all else fails look for a program called LONGBOW that many users like yourself find helpful in running old software in newer Windows versions.
Don't gloss over that last paragraph I wrote: read it, comprehend it, do something proactive about it. You went beyond the norm with Win7 64bit.
Good luck.
Message 5 of 10
stubbes
in reply to: pendean
So you're saying the fatal error is caused by running LT2006 on Windows 7 64 bits, or is that an assumption? Before I start looking into a solution like Longbow, I would like to make sure it's a compatibility error.
Message 6 of 10
Charles_Shade
Uninstall the AutoCAD LT
Autodesk Recommended Clean Install Procedure:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240817&id=2887771&siteID=123112
Uninstall all .NETS and C++ on the computer.
Reinstall the LT 2006 using XP emulation mode and as an Administrator on the System
Open AutoCAD LT 2006 as an administrator and activate. Does it run?
Message 7 of 10
pendean
No, I'm saying if you want a definitive fix there is none as your setup in not supported. No one in the year 2005 was planning on WIndows 7 with LT2006.
If the problem is recent, Windows System Restore back to a month the problem started will fix it.
If the problem is a set of files you started using two weeks ago, fix the files.
You are avoiding my first question: what is the trigger?
Message 8 of 10
stubbes
The trigger is opening any .dwg file.
Message 9 of 10
pendean
Then you need a dramatic fix or more as noted by all so far, or a permanent solution that addresses your unsupported combination of software/OS.
Message 10 of 10
pontiacgp
My Auto Cad LT 2006 (running on Windows 10 in compatibility mode for Windows XP SP 3) had been trouble free but began giving the same Fatal Error today when I clicked on the "open" icon.
Specifically: "Unhandled access violation reading 0x0000 exception at 5fa187abh"
In another, more helpful string, there was a similar issue on Windows 7 solved by updating the display adapter driver.
I updated the display adapter driver and the issue was solved.
This post was intended as a potential answer and not specifically as a reply to pendean, but as a new member i clicked on the wrong button.
Bill
”Boost
