I have recently moved to 2014Lt.
When I open a second file both go super slow. I didnt have this problem with 2013.
It often then crashes the recent error no is d686468fh. any ideas what I should do?
Hello Michael,
I want to explain something about the fatal error message.
Fatal error occurs in many different reasons.
And usually, fatal error message indicates there was a conflict at certain sector of your hard drive. So basically, it tells just a location and this case, I couldn't find any data related on your error message.
But slow speed could be the clue.
If you use Windows 7, please check this technical solution.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?id=18818398&linkID=9240617&siteID=123112
If AutoCAD still crashed?
If an error report window pops up, please enter your e-mail address and send it to us.
We collect error report data to find out what kind of problems our user is going through.
And sometimes our support team find a key to solve the case.
Hello Michael,
I check the file you sent to me and got the message that the drawing file contains AEC objects.
Which means the drawing file was created from AEC product like AutoCAD Architecture.
When I checked, the opening times from AutoCAD LT 2013 and 2014 were almost same.
But after I installed AEC oject enabler on AutoCAD LT 2013,it was shortened.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20129401&linkID=9240818
So I guess, you may already install AEC object enabler on AutoCAD LT 2013 and you need that for 2014 version to work with your file.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21383313&linkID=9240818
