I have terrible lag whenever I am drawing a polyline. It seems like it is taking forever to render the preview of the line when I am dragging the line across the screen. I would prefer to just turn off the line preview if at all possible. So far, I have not been able to find a way to do this. When I say preview of the line, I am talking about the transparent line that follows your cursor after you start a polyline and exists until you click to place the line where you want it.
I am running Windows 7 Pro 64-bit
Dell Precision M6600
8-gb ram
NVIDIA® Quadro® FX 2800M graphics
Thanks!
Solved by Charles_Shade. Go to Solution.
Welcome to the Autodesk Forums!
DYNMODE and the Variables associated with Dynamic Input may be of some help to turn on or off. OPTIONS, Selection tab, Preview (at the bottom left) would be a place to start.
As far as the line that drags behind the cursor it is the line that you are creating and therefore cannot be eliminated I would surmise.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
This was the problem! I set the DYNMODE to 0, and instantly my plines started moving smoothly as I drag them. Thanks!
