I just want to extract the coordinates and number of survey locations that are represented by point blocks from a drawing.
My template is on the desktop and is named
TAYLOR EXTRACT.txt
BL:NAME C008000
BL:COMMENT C008000
BL:NORTHING N0010003
BL:EASTING N0010003
I get the attribute extraction menu
select some points, verify that points have been selected
specify the above template
Specify the export file name
select ok
returns 0 records
Hello
Presently I havn't a PC with ACAD, but just a "crazy" idea :
Have you tried with a "classic" filename : "EXTRACT.txt"
(without any special char, no space, etc)
Bye, Pat
Patrice BRAUD
Hello Steven-G
You are absolutely right !
BL: is required only for props block, for example :
bl:layer c020000
bl:x n009003
bl:y n009003
bl:name c020000
c:quote "
c:delim ,
Bye, Pat
Patrice BRAUD
currently trying:
bl:comment c020000
bl:GNSS_HEIGHT n005003
bl:Northing n009003
bl:Easting n009003
getting invalid field specification
in the properties box I have the following fields I've put the values in quotes
comment "a name or number"
GNSS_Height "4.689"
Northing "87526.317"
Easting "488371.613"
Just a thought so you are not getting hung ont he number of characters: Add two or three to everything 20 to 22, 9 to 12 or whatever.
And do you have a blank a tthe end of yout Extraction file?
i.e After the Easting string did you hit Enter once and only once?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
First Thanks for taking the time to reply
I backspaced to the end of the text & then pressed enter.
added additional places as suggested which resulted in the following:
bl:comment c025000
bl:GNSS_HEIGHT n006003
bl:Northing n010003
bl:Easting n010003
command line replies: 0 records in the extract file
Hello
There is something very strange in your DWG !
Because with my gabarit >>>
BL:NAME C020000
BL:LAYER C020000
BL:X N014004
BL:Y N014004
C:QUOTE "
C:DELIM ,
Comment C030000
GNSS_Height N012004
Northing N012004
Easting N012004
And ONLY if I redefine your Block, I can do a correct (with records) Attribut Extract following the gabarit ...
I have tested with a good old ACAD LT 2004 and with an AutoCAD MAP 2012 !?
SAME problem ! But NO Problem with my new Block with the same attributes ...
Waiting for other inputs !?
Bye, Pat
Patrice BRAUD
