AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Exporting to DWF, or Publishing to DWF, or Plotting to DWF
2 REPLIES 2
cdavis7254
790 Views, 2 Replies
A client wants a DWF.  I'm running 2014LT. I've tryed a number of ways to get it to work.
1) I went to export, dwf, the window opened so I could give it a name & location, I hit save & it appears that it has created the DWF.  When I go to the location, there are no DWF in the folder.
2) I went to Publish, the window opens & I set it to DWF, hit publish & ....I get the "failed to plot" in my plot status.  I've check "publish in background" and un-checked "publish in background".
3) I went to plot & I don't have an option for DWF in my list of printers.
Any ideas would be greatley appriciated.
Cary
2 REPLIES 2
pendean
in reply to: cdavis7254
Looks like you removed/uninstalled the DWG to DWF.PC3 file from your setup. It's there by default during a normal installation of LT2014.
Put it back with PLOTTERMANAGER command's Add-A-plotter wizard. PUBLISH as as as PLOT and EXPORT reply on it.
Do you have a DWF viewer installed? You can't see a DWF without it.
cdavis7254
in reply to: pendean
Thanks, that was the problem!
”Boost
