AutoCAD LT Forum
Exporting to DWF, or Publishing to DWF, or Plotting to DWF
2 REPLIES 2
799 Views, 2 Replies
A client wants a DWF.  I'm running 2014LT. I've tryed a number of ways to get it to work.
1) I went to export, dwf, the window opened so I could give it a name & location, I hit save & it appears that it has created the DWF.  When I go to the location, there are no DWF in the folder.
2) I went to Publish, the window opens & I set it to DWF, hit publish & ....I get the "failed to plot" in my plot status.  I've check "publish in background" and un-checked "publish in background".
3) I went to plot & I don't have an option for DWF in my list of printers.
Any ideas would be greatley appriciated.
Cary
2 REPLIES 2
pendean
Looks like you removed/uninstalled the DWG to DWF.PC3 file from your setup. It's there by default during a normal installation of LT2014.
Put it back with PLOTTERMANAGER command's Add-A-plotter wizard. PUBLISH as as as PLOT and EXPORT reply on it.
Do you have a DWF viewer installed? You can't see a DWF without it.
in reply to: pendean
Thanks, that was the problem!
”Boost
