This is probably a very generic question but I need to know before I by a current version of LT. Is there a way to export files from a newer version of AutoCAD LT to an older version without to many compatabilty issues. Just so you know what I am dealing with I am trying to go from 2015 to 2004. If you can link me to the information or explain it here I would find it very helpful, thank you.
Solved by drjohn. Go to Solution.
DWG Trueview convert should do you OK. I think there is a batch convert in there also.
Be advised that you will lose all of the newer version intelligence (in the drawing, that is ) by doing so. eg: multileaders will not convert back, dynamic blocks ... etc ... etc ...
HTH
DJ
