I've been fighting with the attribute exporter for several hours and can't get anything to generate except for a blank txt file. Below is an example of my template
BL:NAME C008000
DESCRIPTION C016000
I would eventually like to export several more attributes that my blocks have but I figure I should simplify it as much as possible for now. I do have a blank like at the end of the text script.
I've also attached my block that has the attributes I'm attempting to extract.
Solved by Charles_Shade. Go to Solution.
BL:NAME is a placeholder in the Help file. This is a difficult to decipher bit of Help file by the way.
You want to extract Attribute Information.
First you need a block.
The Attrib you have assigned has a Tag named X
These is no Attrib in the attached drawing with a Tag named Description
See attached.
This dwg has a block with three unique attribs
The txt file looks for these Attrib Tags and are looking for Characters , hence the C
Run ATTEXT from within CAD and follow the prompts and questions.
The outp[ut file Drawing2.txt is attached.
This is all very basic to what you can achieve.
Please mark any response as "Accept as Solution" if it answers your question.
Kudos + gladly accepted if you are feeling magnanimous
_____________________________________________________________
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
I have 2 different blocks I want to extract information to for a delimited file. I used the above and that works great for each individual block, but with 2 block it's two different lines. Is there a way to update the ATTRIB.TXT file to allow for this?
