AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Explode points
7 REPLIES 7
Message 1 of 8
Imui
3048 Views, 7 Replies
Explode points
Is there a way to explode points in Autocad LT?
using autocad lt 2011
7 REPLIES 7
Message 2 of 8
pendean
in reply to: Imui
Not everything is explodable: points and lines are among them.
What is it are you actually wishing to accomplish?
Message 3 of 8
hwalker
in reply to: Imui
No you cannot explode points, as that's all they are a single point.
If you're worried about how it looks on the screen type in pdmode and change the setting to 0, which will be just that a single point.
Type in Point in help and you can see what the separate values of PDMODE do.
Howard Walker
Left Handed and Proud
Message 4 of 8
Imui
in reply to: pendean
Hello
I've recived a bolt plan, in wich the bolts are marked as points. Not all the bolts are the same size.
I was trying to change the points to circles of say  20mm and explode them, then to change the remaining circles to 30 and so on.
Now i'll have to take each one at a time.
Thank's for the replys.
Message 5 of 8
bob_mpc
in reply to: Imui
You can change the appearance of the points wih ddptype commans. Set the size in units, not relative to screen.
Boris
AutoCad LT 2021.1.1
Message 6 of 8
pendean
in reply to: Imui
.., but they still are POINT objects, not bolts. So you can't snap of select edges of these shapes. The excellent tip above is a display option and changes nothing about the POINT object.
Message 7 of 8
bob_mpc
My bad, I failed to understand properly the issue. As an excuse - I'm not native English speaker and do not work in English-speaking environment.
I would in this case create blocks of the different bolt sizes and insert them snapping to NODE - unfortunately one by one. Then, send the points to frozen layer.
Boris
AutoCad LT 2021.1.1
Message 8 of 8
Imui
in reply to: bob_mpc
Such a simple question and such a long debate 🙂
Thank you for your replyes.
For what i need right now i'll just asign a diferent colour to diferite size of bolts.
”Boost
