AutoCAD LT General Discussion
Member
lucabugno
Message 1 of 5 (1,142 Views)
Accepted Solution
ERRORE IRREVERSIBILE: Unhandled e06d7363h Exception at 7680b9bch
1142 Views, 4 Replies
10-15-2012 05:53 AM
Hi there,
when I try to print to pdf a dwg file with "DWG To PDF" printer this error appears: Unhandled e06d7363h Exception at 7680b9bch. It occours sometimes not always, I tried to search the problen on the Knowledge Base and in this forum but I couldn't find anything.
Anyone can help me?
Thank you
LT2008 is not supported in Win7, that's why you can't find anything about it.
Win7 has an XP Mode that is designed for older software, explore the topic in Win7's Help or Microsoft's website and see that is the solution for you.
*Expert Elite*
pendean
Message 2 of 5 (1,135 Views)
Re: ERRORE IRREVERSIBILE: Unhandled e06d7363h Exception at 7680b9bch
10-15-2012 06:04 AM in reply to: lucabugno
"sometimes" probably has a lot to do with the DWG file and not the program: or perhaps a circumstance where you are not in the office or "something"?
If all other suggestions fail, Autodesk recommended uninstall/reinstall procedures are as follows
Uninstall: http://usa.autodesk.com/getdoc/id=TS45252
Reinstall (for XP/Vista users): http://usa.autodesk.com/getdoc/id=TS75218
Ensure the user installing/uninstalling and using the product have enough rights to do so (install and reinstall as local administrator):
Unable to run AutoCAD® as a restricted user http://usa.autodesk.com/getdoc/id=TS1055299
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Member
lucabugno
Message 3 of 5 (1,102 Views)
10-16-2012 12:40 AM in reply to: pendean
Thank you for the reply,
I'll try to uninstall/reinstall the program but, I see this problem only with win 7, when it was installed in win XP it didn't have any problem with AutoCAD LT 2008.
In the datasheet I see that AutoCAD LT 2008 is compatible with win XP and vista, but no one talks about win 7.. Is it compatible with win 7 or are there any compatibility problems?
Thanks a lot
*Expert Elite*
pendean
Message 4 of 5 (1,092 Views)
10-16-2012 04:58 AM in reply to: lucabugno
Member
lucabugno
Message 5 of 5 (1,088 Views)
10-16-2012 06:11 AM in reply to: pendean
Thanks again,
I'll try your solution..
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
