AutoCAD LT Forum
ERRORE IRREVERSIBILE: Unhandled e06d7363h Exception at 7680b9bch
4 REPLIES 4
lucabugno
2290 Views, 4 Replies
Hi there,
when I try to print to pdf a dwg file with "DWG To PDF" printer this error appears: Unhandled e06d7363h Exception at 7680b9bch. It occours sometimes not always, I tried to search the problen on the Knowledge Base and in this forum but I couldn't find anything.
Anyone can help me?
Thank you
Tags (1)
4 REPLIES 4
pendean
in reply to: lucabugno
"sometimes" probably has a lot to do with the DWG file and not the program: or perhaps a circumstance where you are not in the office or "something"?
If all other suggestions fail, Autodesk recommended uninstall/reinstall procedures are as follows
Uninstall: http://usa.autodesk.com/getdoc/id=TS45252
Reinstall (for XP/Vista users): http://usa.autodesk.com/getdoc/id=TS75218
Ensure the user installing/uninstalling and using the product have enough rights to do so (install and reinstall as local administrator):
Unable to run AutoCAD® as a restricted user http://usa.autodesk.com/getdoc/id=TS1055299
lucabugno
in reply to: pendean
Thank you for the reply,
I'll try to uninstall/reinstall the program but, I see this problem only with win 7, when it was installed in win XP it didn't have any problem with AutoCAD LT 2008.
In the datasheet I see that AutoCAD LT 2008 is compatible with win XP and vista, but no one talks about win 7.. Is it compatible with win 7 or are there any compatibility problems?
Thanks a lot
pendean
LT2008 is not supported in Win7, that's why you can't find anything about it.
Win7 has an XP Mode that is designed for older software, explore the topic in Win7's Help or Microsoft's website and see that is the solution for you.
lucabugno
Thanks again,
I'll try your solution..
”Boost
