AutoCAD LT Forum
error when trying to plot
5 REPLIES 5
243 Views, 5 Replies
since a while I have a strange problem with Autocad LT 2012 (on my computer with win Vista).
When I try to plot in ANY drawing, I sometimes get an error, and Autocad just shuts down. This happens not always, but at random times (especially when I haven't saved for 30'...Smiley Sad)
Anyone with experience in this issue?
Best regards,
Tom
5 REPLIES 5
Charles_Shade
Corrupt drawing perhaps?
Since you have noticed this to be any drawing do you use Xrefs or maybe blocks?
Have you tried RECOVER or AUDIT on a file after it crashes to see if it reports any errors in the file?
in reply to: Charles_Shade
File corrupt does not seem plausible.
The file(s) do contain xref's (I alsmost always work with them).
Next error I will do an audit. See what that gives.
Thanks.
I have been getting this error too.
I ran Audit and there were no errors.
I have found if I'm viewing model space from paper space it's more likely to occur and since I've started clicking on the paperspace icon just before ploting (AND saving!!) i've not had another crash..... fingers crossed!
Would still be nice to know why this is occuring though.
Charles_Shade
Autodesk Info Center crashes regularly here when I plot but not the program.
There may be a plotting glitch out there.
pendean
>>>...but at random times...<<<
That usually means the error is file related, not the program: it is happens all the time in all drawings it's a program or program setup issue.
It does not mean the file is corrupt (although it never hurt to use RECOVER command to open the file, but you must do so for each Xref separately first), it may mean the plot parameters in that file or in that one layout are invalid or the files they seek are corrupt or missing.
Try to better identify which files do this, and ensure you can repeat it constantly first so that you can confirm it is a problem, and not just a glitch-of-the-moment that goes away.
”Boost
