AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Error : "AutocadLT running out of memory"
3 REPLIES 3
1068 Views, 3 Replies
Dear Autodesk Team,
We are facing the problem of error "AutocadLT running out of memory" and our work completley wasted.
Please let me know the reason and solution for this error.
Screenshot is attached with this message.
Our Hardware details : Dell optiplex 990 and
Software details : AutocadLT 2012 , winxp - 32bit
Waiting for your earlest reply.
Thanks & Regards ,
Swapnil M. Gholap
Application Engineer
s.gholap@frames-group.com
Frames Process & Energy Systems India Pvt.Ltd.
India
www.frames-group.com
3 REPLIES 3
pendean
No Autodesk team here, just us end users like you.
That's a Windows OS message telling you about limited PC resources no longer being available. Start shutting down all background running applications (including any anti-virus or other software that may be scanning AutoCAD and it's files): upgrading to a modern 64bit OS and adding more RAM may help as well.
braudpat
in reply to: pendean
Hello
AutoCAD 32 bits (any version 20xx-201x) has a historical "sound" barrier : about 1.3 Gb used by the 32 bits task "ACAD.exe" !
Even if you have yet 0.5-1.0 Gb windows memory available ... which is the maximum on a 3 or 4 Gb PC with a 32 bits Windows
You must switch to a PC 64 bits with Windows 64 bits (Seven if possible, it's better than Eight : my opinion)
with 8 Gb of Memory !
Bye, Pat
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
inchul.lee
Hi s.gholap,
How are you?
As pendean and braudpat explained, the problem is mostly due to the limitation of 32-bit Windows OS.
In 32-bit Windows OS, for example Windows XP 32-bit, can manage up to 4 GB of memory space. It allocates 2 GB of memory for its own use and allocates only the maximum of 2 GB of memory space to its applications. It is a theoritical number and are shared by other applications running in the background, so the actual size is smaller than that.
The best option is to upgrade to 64-bit OS which allocates 8 TB (virtually unlimited) of memory space to applications.
Here are other things you may also need to check:
  • Install the latest AutoCAD LT 2012 updates
  • Install Windows updates
  • Install the latest hardware drivers (especially graphics driver)
I hope the above is helpful in resolving the issue.
Inchul Lee
”Boost
