Having an issue with error 11.1.6011. For all those familiar with it, I am constantly directed to this webpage to try to solve the issue:
This is a hotfix Autodesk released. If you click on 32bit or 64bit I'm directed to a webpage showing what I believe the .reg file in the supposed hotfix should be, but it's just text. No file. Can anyone help tell me what to do with this info? I know you can turn a .txt file into a .reg file by changing the properties, but then I'm not sure what to do with it. The webpage I'm directed to says:
Windows Registry Editor Version 5.00 [HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Autodesk\Licenses\Autodesk Licensing Service\Parameters] "MDI_Disable"=dword:00000001
