I am having trouble now resizing my jpeg after I have dragged it into my CAd drawing. I usually do this and am able to select the jpeg in my drawing and then grab the corner and resize it to fit in the space I need it to fit in... but I am not allowed to even select the jpeg after it has been inserted int to the drawing...
I am working on the layout space in the dwg, I thought if I worked in model space it would allow me to select the jpeg, this does not help...
Turn those object frames on first: did not catch your LT version, so explore IMAGEFRAME and PDFFRAME, 1 or 2 for a setting.
I use 2010LT
i ended up taking a snapshot of the pdf file, copied it, and pasted into the the dwg. it then allowed me to grab the image and resize as necessary...
thanks for your help though
