AutoCAD LT Forum
entering jpeg into cad, resizing the jpeg
3 REPLIES 3
RBusta
482 Views, 3 Replies
I am having trouble now resizing my jpeg after I have dragged it into my CAd drawing. I usually do this and am able to select the jpeg in my drawing and then grab the corner and resize it to fit in the space I need it to fit in... but I am not allowed to even select the jpeg after it has been inserted int to the drawing...
I am working on the layout space in the dwg, I thought if I worked in model space it would allow me to select the jpeg, this does not help...
3 REPLIES 3
RBusta
in reply to: RBusta
same problem adding pdf files...
pendean
in reply to: RBusta
Turn those object frames on first: did not catch your LT version, so explore IMAGEFRAME and PDFFRAME, 1 or 2 for a setting.
RBusta
in reply to: pendean
I use 2010LT
i ended up taking a snapshot of the pdf file, copied it, and pasted into the the dwg. it then allowed me to grab the image and resize as necessary...
thanks for your help though
”Boost
