Just upgraded (not sure it was truely an upgrade) to LT 2013. When double-clicking an attribute in LT 2009 a nice dialog box popped up that could be tabbed through to each attribute. In 2013 the Enhanced Attribute Dialog box will not allow tabbing, you have to physically click on each attribute item then go to another spot in the box and click again to make the change. Not good. Any suggestions?
Try using the Enter key to move between Attribs instead of the Tab key.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Thank-you Charles, That works.
It sure would be nice if all the changes were clearly and logically explained somewhere. (Please don't link an Autodesk webpage...I've been there and got lost in the excessive verbage 🙂 )
There likely is not one.
That trips me up from time to time too.
