When I use DIST and AREA commands on LT 2011 x64 with dynamic input ON, the result is not always displayed.
I have to use F2 to see them.
A workaround is to restart AutoCAD in order that the result from DIST and AREA to be displayed in dynamic input, but, even so, after a while they stop working.
I mention that for the rest of commands all dynamic inputs are OK.
What is DYNMODE set to? should be 3.
What is DYNPROMPT set to?
Are those the settings that change when the display you want stops working?
I use:
DYNMODE = 1
DYNPROMPT = 1
but I tried with all values for both and nothing changed.
I also do a repair and I updated to Update2.
No change.
