I've downloaded a Dynamic Weld block from a forum. I want to add a Flip parameter. It seems to add ok in Editor but when I go to "Test Block window" it doesn't show up. I've been able to edit all other parts of block (move lines around,etc.) but can't seem to add a new parameter/action. I will attach the block for your perusal.
Thanks for anything anyone can do to help me out here.
Solved by gccdesign. Go to Solution.
I believe it's a visibility state issue. It's still there, just hiding in a different dimension.
In Edit Block, with your ribbon expanded, click the Visibility Mode icon. It's a square / square.
This will show you objects that are invisible in the current visibility state as dimmed.
Click the vertical dotted line for that flip parameter to select it. Then click the Visible icon to make it visible.
Now test it.
GChapp
