AutoCAD LT Forum
Dynamic Block problem.
3 REPLIES 3
Mexpat
659 Views, 3 Replies
I've downloaded a Dynamic Weld block from a forum. I want to add a Flip parameter. It seems to add ok in Editor but when I go to "Test Block window" it doesn't show up. I've been able to edit all other parts of block (move lines around,etc.) but can't seem to add a new parameter/action. I will attach the block for your perusal.
Thanks for anything anyone can do to help me out here.
3 REPLIES 3
gccdesign
in reply to: Mexpat
I believe it's a visibility state issue. It's still there, just hiding in a different dimension.
In Edit Block, with your ribbon expanded, click the Visibility Mode icon. It's a square / square.
This will show you objects that are invisible in the current visibility state as dimmed.
Click the vertical dotted line for that flip parameter to select it. Then click the Visible icon to make it visible.
Now test it.
GChapp
Mexpat
in reply to: gccdesign
You da man. Worked great. Thanks.
gccdesign
in reply to: Mexpat
Here it is back again, with the fix I described to you, plus made annotative.
GChapp
”Boost
