I'm a student of architecture in Belgium and i have the same problem.
DWG To PDF.pc3: This plotter configuration cannot be used for one of these reasons: the driver cannot be found, the device cannot be found, or the driver has a problem. The None plot device has been substituted.
What is you're advise for me to solve this problem?
Thank you
Greetings
Do a repair install of the program as advised above. DWG to PDF.pc3 should be there and usable.
Also:
Opening a Plot dialog where the Windows installed printer has either been changed, deleted, or is from another system: i.e; You opened a drawing created by someone with Printer X and you do not have Printer X.
Assign a printer from your system to the drawing and Save. The printer will be available to you the next time you open the file. Rreview PAGESETUP Command to create and update Layout tabs.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
