Hi I'm using the DWG To PDF.pc3 driver to plot a drawing that contains a transparent gradient hatch and when I plot this it does not show up the transparent gradient hatch, it simply misses it out. However if I use the pdf995 driver it plots it with no problems, all plot settings are the same. But the pdf995 river provides terrible quality pdf's to be put on a screen!
Does anyone have any ideas on how to resolve this or can recomend a high quality and preferably free pdf driver that wont cause this problems?
See attached pdf's. I'm using LT 2012, but have also tried LT 2014 and full autocad and all repeat the problems.
Mick
Hi Dean,
Attached my dwgtopdf.pc3 file. Following your last reply I have done some further testing on the issue, I have discovered from the layout tab:
Mick
edit - I had to remove the .pc3 extension to the attached file so that I could add it
