Hi I'm using the DWG To PDF.pc3 driver to plot a drawing that contains a transparent gradient hatch and when I plot this it does not show up the transparent gradient hatch, it simply misses it out. However if I use the pdf995 driver it plots it with no problems, all plot settings are the same. But the pdf995 river provides terrible quality pdf's to be put on a screen!
Does anyone have any ideas on how to resolve this or can recomend a high quality and preferably free pdf driver that wont cause this problems?
See attached pdf's. I'm using LT 2012, but have also tried LT 2014 and full autocad and all repeat the problems.
Mick
It might be an error in the PC3 file. I've just PUBLISHED it and changed from Plottter named to PDF and it printed the hatch fine
Howard Walker
It still doesn't work for me when changed from plotter named to pdf. Can anyone recomend a high quality pdf driver that won't have this problem?
I don't get your second PDF that you have posted. Do you want the countries (I assume they are countries) to be hatched on not?
In your second PDF all I see are the country outlines
Howard Walker
default DWG to PDF.pc3 wich came with the AutoCAD LT 2011
only thing is that i checked the plot transparency option
Hi Dean,
Please see attached screenshot. I have omitted the pen settings as they contain my companies name.
Mick
edit - screenshot now correctly attached!
