All of a sudden I cannot print or export a file to pdf. When I do it does not appear as an engineering drawing. The lines appear as if drawn with a fat marker. Text and dimension lines do not appear. I opened one of your sample drawings that came with Autocad and it did the same thing. Therefore, I am concerned that something is corrupt in Autocad or a setting has changed on software launch.
Solved by wei503. Go to Solution.
I got that you are using AutoCAD LT for Mac.
Here are the solutions:
Open the Page Setup dialog, if you are using a plotstyle, please update it as for all colors the lineweight shall be 0. If you are not using a plotstyle, you can uncheck the option "Print object lineweights" in the Print Options in the Page Steup dialog.
Wei
I also am using Autocad LT 2015, I tried all of your recommendations (line weight to zero and unchecked the "print with plot styles" and i still cannot get it to print a pdf
