When ever I open a drawing from the file menu or open file icon, the preview pane is missing from the dialogue box. I is there if i use file new or when I insert a block of file. Please can anyone help. Please see attached screen print.
Acad LT2013
Solved by bgingerich. Go to Solution.
That looks like a graphics issue.
Computer and Video Specs?
OS - Are you running Aero theme (If that is part of your OS)?
Hardware acceleration may be another item to look at (In my case having it On works better overall.)
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
This may be the solution for you.
There are two possible ones there.
(if ("mysolution"=answer) then (click "Accept As Solution"))
Hi there,
i've looked at your solution but editing the profile only seems to be an option for Full AutoCAD users. I can't seem to apply this fix to LT 2014.
Any ideas?
It's right there in the registery... This is what it looks like in 2010 LT. Is it set to 1?
The other question if it's not there: do you have a registery cleaner running? If so, make an exeption for AutoCAD so it doesn't mess stuff up again and do a repair install of AutoCAD.
Boom!! that worked!
Thanks ever so much. My lack of admin rights didn't allow me to access the reg editor but my companies IT people have sorted it
Thanks again,
Neil
I have this same problem but with AutoCAD 2014 full version. Can you tell me how to find "previewvisible" in the registry editor?
Thank you,
Melissa
Does this fix apply to all user profiles, or is it only in the user that is currently logged in?
