AutoCAD LT Forum
Drawing file is not valid
9 REPLIES 9
Message 1 of 10
frank9700
754 Views, 9 Replies
I get an error message (Drawing file is not valid) when I try to open Autocad 2004LT .dwg file. The file is 573 Kb. There's obviously some information in the file which I can't read. What can I do to view this file?
Frank
9 REPLIES 9
Message 2 of 10
in reply to: frank9700
Try insert it as a block into a working dwg. But, the error message does not sound good. This is the error you get if you try to open a non-dwg file that have been renamed to dwg. Open it in Notepad and check rhe first 6 characters. It should look something like this: AC1018 The numbers can be different due to the version of LT that created the file. Conny "frank9700" skrev i meddelandet news:10111365.1079668748383.JavaMail.jive@jiveforum1.autodesk.com... > I get an error message (Drawing file is not valid) when I try to open Autocad 2004LT .dwg file. The file is 573 Kb. There's obviously some information in the file which I can't read. What can I do to view this file? > > Thanks, > Frank
Message 3 of 10
frank9700
Hi Conny,
Thanks for your quick response. I opened the file with Notepad and it specified that "this file must be converted with BinHex 4.0." It was followed with lots of odd characters. I went on the internet to try to find BinHex 4.0, without success, so far. Can you help?
Frank
Message 4 of 10
If RECOVER command can't open it, and INSERTing the file into another can't open it, time to look for a backup copy on your backup system or disks or tape, or the BAK extension, or even an SV$ extension file, to recover. If you have access to a 3rd party CAD program that can open DWG files, it might recover it too. -- Dean Saadallah Add-on products for LT http://www.pendean.com/lt --
Message 5 of 10
I have tried these procedures without any luck. When i go to open the file, it will show a preview of the drawing. i have tried to recover and insert as a block. nothing works. any more suggestions
Message 6 of 10
Preview means nothing: it's simply a hidden image snapshot what the
file worked fine, it is NOT and NEVER is an indication of the actual
status of your file.
If nothing works, the file is dead. Sorry. Try posting it here for
others to try if you want.
Dean Saadallah
http://LTisACAD.blogspot.com
Message 7 of 10
Try my last two suggestions: you're still messing only inside the
problem file.
Also make sure the files are not from ADT, if they are, your architect
needs to export them for you down to 2D.
Dean Saadallah
Message 8 of 10
oops, sorry, this landed in the wrong spot. please ignore.
Dean Saadallah
http://ltisacad.blogspot.com
Message 9 of 10
BinHex is an ecoding format and might be opened, or un-encoded uising the likes of Winzip. In the WinZip Open Dialog, under file types at the bottom, chose "Encoded" files, which include such types as *.b64 and *.bhx (binhex). You *might* have to rename the file to change the extension to .bhx.
.... OR! I could be all wrong
JimL
Message 10 of 10
the file that i am useing was created in autocad and no other program has opened this file. this has happened to a number of files that are to large to place on this website.
”Boost
