I was using the autocad LT 2014 on existing drawings in my C Drive and I lost all the drawings. I had used the autocad for about three times before on these drawings but on 7/21/2013 I opened the 1st floor plan and after working on it I could not close it. Then I opened the 2nd floor plan and worked simultanously on it and saved it but could not close the two files. I proceeded to open the site plan and after working on it I tried to close all three files and had an error message and the files closed. Each of the files had about 572 KB but now each has 0 KB. I am not able to open these file after the error occured. I am wondering whether my drawings were hacked by someone that has access to your online product. These drawigs are for a 10,000 sq ft house I had designed for a client and now I can not deliver the drawings for construction.
My response wasn't meant to be snarky, just relating to the heat of the moment when you may have lost / lost a file and got that O**** realization. Have you got a daily backup file, where at least the loss is redoable, what about the restore function, did you get this error message when you tried to open the drawing again? Sorry but as a new guy that's all I got. Lets just hope this isn't a virus condition, do a scan as a precaution.
Welcome to the Autodesk Forums!
As is said above.
Do you do any type of File backup or use the Create .BAK file when you Save a Drawing?
You wrote that you were working in LT 2014. Take a look at the TEMP folder (%TEMP%) from Windows Search in Start. Maybe there is a saved file there.
If you are not sure where the BAK file is located you can look under OPTIONS, Files tab, Temporary Drawing File Location.
And why are you looking for the LT 2012 download?
Hacked online product? What are you referring to?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
cmudesign I'd be curious to know what happened when you resolve this problem. Do have a question though, were you using autocad 2012LT for the majority of your CD set, then switched to autocad2014 (used the three times) and then had the failure?
