Turns out I am not the first to point all of this out to you, were you
hoping for an answer that was les painful? We all do sometimes.
Your problems, if I may be so blunt, are self created. I appreciate you
having legacy drawings with the same issue, but we all make these kinds of
judgment calls at one point to solve a problem that come back to bite us in
later versions of many software, AutoCAD included. You are not the first one
to pick an option very few have and get hurt, and not the last.
The same issue exists in 2000/2000i/2002 with your drawing, so you are kind
of stuck: stay where you are with LT97/R14, or start making the change now,
and when in legacy drawings, carefully dimension and be aware of what you
are snapping to. No one has the time to recreate old stuff, but if you
re-cycle often like most of us, it might well be worth it in the long term.
Autodesk is not typically known for rewriting code to suit individual needs.
Changing software would be a lot more painful.
Good luck friend: you are at a very tough crossroads and only you can move
on to the right path. Have a restful weekend, and come back on Monday with a
fresh look at how to solve the problem in-house and help your users get over
this issue with more practical solutions, ad help them avoid the problem in
the future with new drawings.
Dean Saadallah
http://www.pendean.com
Expanded Links Page
http://www.pendean.com/lt/links.htm
"Dean Saadallah" wrote in message
news:2B96F82475794E43EA74B5E88691191B@in.WebX.maYIadrTaRb...
> OE problem (Operator Error).
> OK, your drawing problem seems to be exclusively related to the SOLIDs you
> created on layer "new-stepsdim3" on the bottom right 3D image at the brown
> colored dimensions. Erasing the SOLIDs makes the mystery Osnaps go away.
> Not sure why you use SOLID command to create the 3D 4-sided square tubes,
> but SOLIDs typically allow Osnaps to endpoints and intersections and
> midpoints, and while hovering over the viewport you were actually snapping
> to available Osnap points hidden by the top visible layer of the tube. In
> other words, you created the condition in which you added additional
OSNAPs,
> but because of HIDE being on, you did not see them. Turning off HIDE in
the
> viewport would have revealed these 'mystery' Osnap points to you.
> So, first, why not use one of Full AutoCAD's 3D entity command to create
the
> tube, instead of doing it the hard way with SOLID? LT2002 can easily see
and
> handle these items, no need to explode etc.
> HELP in AutoCAD is an excellent place to start to learn how to create and
> use 3D objects.
> Full AutoCAD, unlike LT97 and LT in general, is really adept at creating
3D
> objects and stuff: basic but very handy. Since you are in Full AutoCAD,
> slowly but surely start sliding away from LT's limited 3D abilities and
> explore.
> And while dimensioning in a viewport, be careful and watch what you re
> dimensioning: as your image posts repeatedly show, when AutoCAD says it is
> snapping to an ENDPOINT, and you do not see on, turn HIDE off and watch
what
> you are really snapping to.
> Have a good weekend, and enjoy full AutoCAD to it's fullest ability next
> week.
> NEXT!
> Dean Saadallah
> Expanded Links Page
> "Joe" wrote in message
> news:3d53fb5c.19892493@discussion.autodesk.com...
> > Actually, the problem file was uploaded a while back and discussed
> > in the AutoCAD 2002 forum.
> > Starting from a blank drawing, I have been able to consistantly
> > reproduce the "snapping to hidden lines" problem. Since it happens on
> > both LT and the full blown version, and on different computers and
> > operating systems, I am assuming it is not unique to me.
> > Joe Dunfee
> > On Fri, 9 Aug 2002 09:48:50 -0700, "Dean Saadallah"
> > wrote:
> > >Without a sample post of this phenomenon, right now the problem seems
> > >exclusive to you and your files. Your issue does not seem to have been
> > >reported yet, a year after the program has been out.
