We developed Multi-Batch in 2001 and to date it has worked successfully with AutoCAD LT and AutoCAD Full versions. Similar to ScriptPro it allows you to automate many commands in AutoCAD. It has five wizards for creating new routines including two for plotting, plus over 60 standard routines to get you started.
Script routines can be very powerful and a great time saver. Once you know what they can do you can start to set up your work around them. For example you can set up your drawing sheet to make it easier to fill in for issuing, change attributes, extract attributes, purge, recover, audit, plot, save as, xref etc. Any command that can be entered on the command line can be automated to run on hundreds of drawings, saving you time and money.
See what current users have to say at http://www.multi-batch.com/testimonials.htm
Download a demo now to see what savings can be made
Patrick
