AutoCAD LT Forum
*distance - distance
7 REPLIES 7
Message 1 of 8
421 Views, 7 Replies
I am sure there is a simple explanation - but it is beyond me!
For years I have edited my aclt.pgp file to have the shortcut for *DISTANCE
as ds.
This morning I received a drawing package from an engineer who uses an add
on program with autocad to somehow convert his drawings to scale in model
space????
When I tried to establish what was happening I used the ds command to
measure something and got 'distance = 0 (read only)' which would seem to
indicate that I was invoking the system variable rather than the distance
command.
I tried typing 'dist' instead of 'ds' and lo and behold the distance command
worked and allowed me to measure the distance. When I tried 'ds' again I got
'distance = 150 (read only)' - this being the stored distance of the
measurement I took with the 'dist' command - (I assume).
I checked my aclt.pgp file and sure enough the shortcut for *DISTANCE is
still 'ds' and there is no 'dist' shortcut anywhere at all.
I find now that the shortcut 'ds' does not work on any drawings.
I have opened the original engineer's drawing on two other identical
computers, which have the same aclt.pgp file as mine and they work fine.
I did a system restore to go back to several days before I opened the
Engineer's drawing and this had no effect.
Any explanation / help would be much appreciated - I want my shortcut back.
system spec
Operating System System Model
Windows XP Professional Service Pack 2 (build 2600) eveshamvale
MS-6743 Ver1.1A
Processor a Main Circuit Board b
3.00 gigahertz Intel Pentium 4
16 kilobyte primary memory cache
1024 kilobyte secondary memory cache Board: eveshamvale MS-6743
Ver1.1A
Bus Clock: 200 megahertz
BIOS: Phoenix Technologies, LTD 6.00 PG 09/17/2004
Drives Memory Modules c,d
160.04 Gigabytes Usable Hard Drive Capacity
132.91 Gigabytes Hard Drive Free Space
SONY DVD RW DW-D22A [CD-ROM drive]
SONY DVD-ROM DDU1613 [CD-ROM drive]
3.5" format removeable media [Floppy drive]
WDC WD1600JD-00HBC0 [Hard drive] (160.04 GB) -- drive 0, s/n
WD-WCAL93055875, rev 08.02D08, SMART Status: Healthy 512 Megabytes
Installed Memory
Slot 'A0' has 256 MB
Slot 'A1' is Empty
Slot 'A2' has 256 MB
Slot 'A3' is Empty
Controllers Display
Standard floppy disk controller
Intel(R) 82801EB Ultra ATA Storage Controllers
Primary IDE Channel [Controller]
Secondary IDE Channel [Controller] LogMeIn Mirror Driver [Display
adapter]
RADEON 9550 [Display adapter]
RADEON 9550 Secondary [Display adapter]
Iiyama A902MT VisionMaster Pro 451 [Monitor] (18.2"vis, October 2000)
7 REPLIES 7
Message 2 of 8
The command is DIST: nothing else, look it up in HELP. Always has been,
still is three versions later.
There is a DISTANCE variable that reports only the last findings of the
command DIST and is read-only in nature.
I'm not sure an add-on you don't have that was used by an outside vendor
triggered this, perhaps these files are just ignoring your PGP setup somehow
by accessing another file.
No amount of system changes will change AutoCAD commands or variables.
Sorry.
Perhaps your PGP file also defines DIST, or something.
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
Message 3 of 8
Try typing in ALIASEDIT and ensure there are no duplicate aliases.
Sometimes D is assigned to DIMSTYLE. Either change it or delete it.
Change DIST to D and delete the DI = DIST entry.
Close the window.
Now make sure the acad.pgp file says
D,*DIST (not D,*DISTANCE).
Restart autocad and it should work. Hope this helps!
Message 4 of 8
Does a REINIT work (before PGP edits and an LT restart)?
Message 5 of 8
There is no ALIASEDIT in LT.
Dean Saadallah
http://LTisACAD.blogspot.com
Message 6 of 8
JPOlbrys
You can edit Alias's in 2010 LT.
Message 7 of 8
Yep, that is true! Good isn't it!
Message 8 of 8
TheRuinner13
Thank you Corinna!
Windows 7 Pro, HP Z400 w/Dual Acer Monitors, 24G Ram, AutoCAD 2013~2015e
”Boost
