Has anyone had this issue: Make adjustments to the Display resolution (Arc & Circle smoothness, Segments in a polyline curve) on the Display tab in the Options dialogue box. Hit the Apply button and then go back to work. Then during the same drawing session (after working for 20-30 minutes including several manual saves), the Display resolution reverts back to a previous lower resolution setting. I know this because all of a sudden my lines and curves are no longer as refined as I want to see them. The program seems to do this all by itself. Is there some master setting that I am missing in order to hold the display resolution setting?
Solved by sthompson1021. Go to Solution.
Hi, check the VIEWRES settings in your layouts, both in paper space and model space in the layout. If they are different then you have set in model space, it will change the setting in model space when you switch to a layout and then back to model space. I should say that this only happens in 2013 and newer releases. Here is link to a earlier discussion about it.
http://forums.autodesk.com/t5/autocad-2013-2014-2015/viewres-question-layout-to-model/td-p/4855099
Thank you, pendean. You give many helpful points which I will try. I am also full admin on my pc, so that should not be the problem. The thing that I can't understand is why the display resolution setting seems to change by itself during my drawing session.
Thanks for your reply!
Alan
