Show only
Search instead for
I had modified several macros that I found in these groups (dimension and bearing macros) to work on my system. When I was finished with the file, I saved it (with the button intact) and closed LT. I opened another fil today expecting the macro to be there but it has dissappeared. How do I ensure that any macros I make will stay in my custom menu? Or should they all be saved in a text backup file?
I started the text back up so I think that's a great idea.
Did you do any registry or hard drive cleanup between the
opening and the closing?
I use CleanMyPC-Registry Cleaner and it will take AutocAD
dump files and others and delete them if I don't un-check them first. The result is missingmacros and desktop setup.
A windows restore will bring it back.
You didn't mention which version you're running, but if it's 06 or newer, try using the 'cuiload' command. Unload the files that are loaded, & then reload them (making sure to reload the cui file you saved the changes to if it was not the aclt.cui). I had problems with all of my menu customizations disappearing until I did this.
I'm running 2005, so no cuiload for me. We do have a seat of 2007 that I am going to try that on though. I went ahead and started a text file for backup. Fortunately the changes I made were still fresh in my mind.
BTW no reboot or cleanup between closing one project and opening another.
