I'm experiencing disappearing icons / buttons on a machine running LT 2009 and Windows 7. While working in a drawing, they sometimes disappear and you can run the mouse over them to make them show up again. I suspected a video card, replaced with a much better 2gb card and it is still happening (although not as much now).
Everything is up to date (service packs for LT and Windows). Machine has 8gb of RAM, an SSD hard drive, and I have other identical setups with no problems.
Any ideas on how to fix the issue?
Hello from France
ACAD or ACAD LT 2009 is not at all supported on Win Seven !
So I suspect a graphic driver problem related to Window sSeven !?
1) Have you tried to disable ALL special graphic features of Win Seven : Aero, etc ...
2) Have tried to re-configure the graphic video driver to run in 15/16 bits color mode (32000/65000 colors)
instead of the normal color mode (24/32 bits - 16 millions color mode) ?
Bye, Pat
Patrice BRAUD
Other things to check:
- ensure hardware acceleration is turned on; if it is, then try turning it off (diagnostic measure) - if it works "off" and not "on", then its definitely the graphics hardware
- ensure the graphics hardware being used is, in fact, your discrete card and not the on-chip hardware found on newer processors
