Hi, I am entering the following text and it is being converted to a date. How do I prevent this?
entered: 15-08-61
result: 8/15/1961
Autocad will not allow me to enter 15-08-61. If I enter '15-08-61, then the ' is printed and the text size is reduced. (excel allows the user to put ' in front of anything and excel will leave it alone).
I turned off "spell check". No good! any ideas?
Solved by edwin.prakoso. Go to Solution.
Are you working in AutoCAD table? Similar to Excel, you need to change the data format to text, to prevent AutoCAD changing your format automatically.
Select the cells you want to type the date, then from contextual ribbon tab> Cell Format panel, click Data Format.
Change the format to text and try to type again.
pendean: you are correct. I have inherited this drawing from a former employee and am trying to correct some things. He has set up some sort of table and it does behave in a different manner than AutoCAD. I will have to research this more...
edwin.prakoso: thanks, you nailed it. Now I can submit my project on time.
I work with excel a lot and I work with AutoCAD a lot, but have not worked with them together very much.
million thanks
million thanks
