Actually open up the DDIM command, and make sure you are settings
in the various Tabs are saved to your DIMSTYLE and you are not
creating a sub-dimstyle.
QLEADER, although it should respect your tick of choice if set
through DDIM, has it's own settings window. Start the command,
then type S and hit ENTER: a new pop-up appears, and you can set
QLEADER parameters there.
HELP in AutoCAD can explain all the above.
Dean Saadallah
www.pendean.com
"Jeff Brown" wrote in message
news:7BEFCEFC1660A2C904B5371EFB45377E@in.WebX.maYIadrTaRb...
> I have tried every trick in the book to get the new 2000i
Dimension styles
> to have an archtick with an arrow leader sub style.
> The settings are never saved when the drawing is opened again.
There is no
> "save" button in the dialog box.
> If I set the variables up in R14 with the parent style as a
tick and the
> sub-style leader as an arrow, then the settings work and are
saved and
> usable in 2000i.
> I have followed the instructions for setting up the new
sub-style in 2000i
> and the settings always revert to just archtick.
> I have had luck with the sub-style radial, diameter and angular
settings
> saving as arrow styles. The Quick leader seems to be the
glitch.
> Anyone have this problem?
> JB
