I AM DIMENSINING A NEW PLAN AND GETTING MULTIPLE REASSOC FLAGS? HAVEN'T HAD THIS PROBLEM BEFORE?
TRIED RESETING DIMASSOC FROM 2 TO 0-RESTARTED PROGRAM, NOT WORKING.
WHEN I SELECT "REASSOC" FROM FLAG I GET AN OPEN X AT ONE POINT- I SELECT AND I'M PROMPTED WITH 2ND ("X" IN BOX) I SELECT, NO CHANGE?
ANY ASSISTANCE WOULD BE APPRECIATED.
If one end of your dimension is snapped to a paper space object and the other end to a model space object, the dimension will not be associative. With the ANNOMONITOR turned on, you'll see the yellow bangs [!] to indicate a disassociative dimension.
As Dean stated, DIMASSOC should be set at 2 in order to create associative dimensions. However, even if that's the case, it is still possible to create disassociative dimensions, as with the process described above.
Hey Zac,
So how do you detemine which object it is snapping to Model space or paper space? and how do you force it to pick one or the other?
thanks,
Le Hien
