I have made changes in dimensionstyle manager, and I would like to transfer my new dimensionstyle to another document. How is this done? I have tried to copy the dimstyle from one file to another in designsenter, but it seems like it isnt possible. Can anyone help me with this?
thanks,
Elsbeth
Solved by Charles_Shade. Go to Solution.
Drag and Drop from Design Center (ADCENTER) is an option. You should drag from the Open Drawing in Design Center to the Drawing itself, not the Dimstyle List of the target drawing in the Design Center window. To do this there would be two or more Open Drawings in Design Center.
Copy / Paste and dimensiopn entity from one file to another is an option.
Saving the drawing with the Dimstyle as a Template and using this is an option.
Having the Dimstyle in a BLock and Inserting the Block is an option.
Please mark any response as "Accept as Solution" if it answers your question.
_____________________________________________________________
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Thank you! you made my day! noone else in the office knew, so now I can spread the word...
Elsbeth
