I opened a floor plan that had existing dimensions and I noticed that if I move a wall or touch the dimension the text changes to a way bigger demension text - it's like it changed dimension scale - but only the numbers in the text changes not the size or dimension lines. Is there a setting to prevent that from happening? Any help greatly appreciated.
What is the DIMSTYLE assigned to these dimensions?
What is your current active DIMSTYLE?
Is this drawing from AutoCAD Architecture or similar, or one of your own from LT?
LT version?
What does "touch the dimension" mean exactly?
It is AutoCad Lt 13 I think your correct. There are 2 vports with 2 diffrent scales and they are both using the same Dimstyle.. Some of the Dimensions if I stretch a wall it will change the dimension to a higher number it. I'm just wondering if I should just purge all dimensions and redo..
It changes the numbers in the text they change to a bigger dimension size, for example if it's 2'-0" if i try to stretch the dimension it will the dimension text will change to 96'-0"
