AutoCAD LT Forum
Dimensions not showing in layout paper space
1 REPLY 1
P1eterVan
4193 Views, 1 Reply
For some reason my dimensions are not showing up in the layout in paper space. They are in a seperate layer called "DIM".
Any hints?
Thanks.
1 REPLY 1
edwin.prakoso
in reply to: P1eterVan
Are all dimensions are not showing? Are they disappear on all viewports?
Check the layer properties when you open the viewport with missing dimensions. It might be the layer properties is overriden for that specific viewport.
And also check with annotation scaling. It's possible that the dimensions are not showing because the annotation scale is different with viewport scale.
If this post solves your problem, please mark it as solved. It will help others with a similar problem to find a solution.
Kind regards,
Edwin Prakoso
LinkedIn | Website | Twitter
”Boost
