Hello all,
Is there a way that I can make the length of the dropdown menu (shown below) for the Dimension Styles longer?
It is difficult to select the correct dimstyle.
Jeremy
Solved by pendean. Go to Solution.
One way that will work for sure is to put each of the DIMSTYLEs on a Tool Palette. Having them there will give you other useful options as well.
Dave
Didn't DotSoft have an add-on that would do that a while back?
Albeit with older software I believe.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Yep, QuickPik
Been a while but I did use it before the Ribbon made life so easy.
